Annoying squeak
Old Jun 5, 2014 | 04:01 PM
D_engel's Avatar
Originally Posted by Monte417
Gotcha
Not to thread jack too much, but were those Teraflex links?
Old Jun 5, 2014 | 04:48 PM
jrod250's Avatar
Originally Posted by D_engel
I hadnt read your post before bro, but I do agree with you. Yours is a worn bushing that allows the steel insert to rub on the mount. His is just clevite, and only clevite, rubbing on the bent bracket. The bushing is not worn out, its just being squeezed slightly around the edge. This would not cause a squeak so I was trying to save him the time and effort spent trying to straighten out the bracket.
Thank you. I have no idea where the heck it's coming from and it comes and goes.
Old Jun 5, 2014 | 04:57 PM
Monte417's Avatar
Yep they sent me a new set for half the price which I thought was messed up they should have sent then to me for free. I thought there was a lifetime warranty but apparently not on bushings
Old Jun 5, 2014 | 05:23 PM
D_engel's Avatar
I figured as much. Those are the links I have and I've noticed the rod end has very little misalignment. I'm sure mine will fall apart at some point too. Thread jack over
To the OP, hope you get this straightened out. Sorry if I came across as a dick--I do that from time to time.
Old Jun 5, 2014 | 08:10 PM
jrod250's Avatar
I figured as much. Those are the links I have and I've noticed the rod end has very little misalignment. I'm sure mine will fall apart at some point too. Thread jack over To the OP, hope you get this straightened out. Sorry if I came across as a dick--I do that from time to time.
No need to apologize at all, and no dickness detected. Lol
Old Jun 30, 2014 | 04:50 PM
jrod250's Avatar
Found my squeak. After I installed my MORE skid plate, I didn't get the motor mount bolts tight enough. Tightened the down and no more squeak
