Another axle question
Old Mar 10, 2013 | 02:06 PM
topdown89's Avatar
Default Another axle question
I am currently running a d44 in the rear which I am perfectly happy with. However, my front axle is the stock d30. Right now I have 33" tires and do light wheeling which is fine for what I have, but I am either going to go up to a 35" or a 37" tire, and my question is should I build up this axle or go ahead and swap for a d44? Is one recommended over the other depending on the tire size? As soon as I get new wheels, my wheeling will go way up
Thanks in advance
Old Mar 10, 2013 | 02:20 PM
zpike00eb's Avatar
Many will say the limit for the D30 is 35's, especially when you start to add stress to it by adding steeper gears or lockers. I ran 35's on my D30 with no issue, but I would add gussets if you plan to wheel.
37's will work on a stock D30 if you stay off the trails. I wouldn't recommend running a D30 with 37's under any off road condition, Most will say a dana 44's max wheelable size is a 37.
Save yourself the headache and get the 44.
Old Mar 10, 2013 | 02:31 PM
Ryan0260's Avatar
If you can afford it, the D44 will be the best long term option for either size tire. If you do decide to keep the D30, I would reinforce it and stick with 35's.
Old Mar 10, 2013 | 02:47 PM
topdown89's Avatar
Alright so sounds like it'd be best to do 35s, so gussets? Truss? Anything else? Any recommended brands?
Old Mar 10, 2013 | 03:21 PM
Rocky Clymer's Avatar
Keep in mind a stock D44 front will have the same inner Cs and axle tube as a D30, the only difference is the pumpkin/internals. So unless you get a built aftermarket D44, you will inherit some of the weakness of the D30. I gusseted and sleeved my D30, went with RCV axles and ARB locker and run 35s comfortable off road.
Old Mar 10, 2013 | 03:30 PM
topdown89's Avatar
So you're running a d44 axle in the 30 housing?
Old Mar 10, 2013 | 03:32 PM
nthinuf's Avatar
If you are thinking about 37's, plan on kicking yourself in the ass for wasting money on 35's and d30 upgrades.
Old Mar 10, 2013 | 03:36 PM
nthinuf's Avatar
No, they are basically the same housings. The d44 just has a larger center section to fit the bigger d44 gears. Same tube diameter and thickness, same ends/c's, same brakes, they even use the same outer axle shafts. (the difference is the inner shafts and the r&p/carrier/locker)
