another esp question
I HAVE used the search function but got a question. i have an 07 and seems as the wheel trick wont work (i tried many times) because it was not programmed into the ecu and i dont want to pull a fuse or cut a wire. will a tuner allow me to turn it off or let it not be not so up tight?
Originally Posted by gunbo75
You can have the dealer flash the computer and then you can do the steering wheel dance.
