another lift question
Old Nov 20, 2007 | 06:18 AM
bavfc3364's Avatar
Default another lift question
thinking of lifting the jeep soon. not sure waht lift is good looking to go 2.5-3 inches. also not sure what other things to consider with the lift. i have read to also use a 3/4 spacer in the front to even out. are there any problems with shaft length using a 2.5 or 3 inch lift. i have a 4 door.
Old Nov 20, 2007 | 06:20 AM
Piginajeep's Avatar
if your talking about driveshaft length. you'll be fine
Old Nov 20, 2007 | 06:23 AM
bavfc3364's Avatar
just checking to see what will be needed to do the lift. i saw a nother area on drive shafts, wasn't sure if that was 3 inch problems or 4 inch and bigger
Old Nov 20, 2007 | 07:59 AM
kidjeep's Avatar
What you might have to consider depends on what tire size and type of terrain you're planning...
From what I have read here, you will be fine with the 3" lift and stock driveshafts.
