Another MPG thread, but more difficult?
Old Dec 18, 2008 | 11:11 AM
northsidejeepin's Avatar
Question Another MPG thread, but more difficult?
Can someone do a basic breakdown for the fuel economy difference between 2 identical rubicons with the only difference being rear end gears, 4:10 vs. 5:13?
Is this even possible to calculate? Reason I am asking this is I have read I can achieve better MPG if I re-gear. Is this true, how would I calculate the answer?
Thanks for any and all answers!
Old Dec 18, 2008 | 11:13 AM
08SaharaM6's Avatar
It is benefitial to regear with a larger tire. I would not recommend regearing a stock Jeep. Your mileage would be worse with stock tires and 5.13's.
Old Dec 18, 2008 | 11:33 AM
I guess I should mention I am running 37'' tires. I am just trying to justify the cost for gears on saving gas. Maybe this is just a wrong thought.
Old Dec 18, 2008 | 11:54 AM
RedneckJeep's Avatar
37s and 4.10 gears? iwould just about be ready to lay down a C note that you'd get better mileage with 5.13s, but I don't know how you drive. No way to calculate this, because there are so many variables involved. Getting all that weight rolling with 4.10s has to be a chore for that Jeep compared to stock. Regearing would bring back the leverage, and likely improve mileage. I have to end with this........if mileage is really what you want, go get a Prius.
Old Dec 18, 2008 | 12:53 PM
Thanks and no thanks! The whole point is not to have great gas mileage, it is to justify the cost of re-gearing using fuel economy as leverage.
Old Dec 18, 2008 | 12:54 PM
Originally Posted by BLKRUBICON
i run 35s in the winter and 37s in the summer. I also upgraded to 5.13 YUKON gears along with the Hypertech Max power Programmer. I have an auto so the Programmer was very important sice it not only correct the speedometer for the larger tires but corrects and remaps my shift points for optimum performance and tyhe choice of gas you use which is 93 octane for me. So with all this I get just around 14 to 14 MPG depending on how much I romp on my JK. I also have a CIA and MRBP exhaust which I have no idea if this effect fuel miledge. But DEFINATELY regear and if you have an Auto the Programmer is a must. The pick up and acceleration with these mods make it feel like I was pushing around my stock 32s. Best I could do, Hope it helps
Thanks, best answer yet, but as i side note, I average 14 with stock 4:10's and 37'' tires.
Old Dec 18, 2008 | 01:23 PM
RA070424's Avatar
Former Member
Hypothetically, let's say you had 5.13's. You'd get decent mileage around town with those big beefy tires, but then you'd be driving at 3000 RPM all over the highway at 62 MPH, give or take. So you'll get 15, 16 MPG around town, and 12 or 13 on the highway.
On the other hand, let's say you go lower. 4.10's. Highway is good, around town not so good.
Mathematically:
$1200 for gears. $1.55 for a gallon of gas. You could buy 38 fill-ups (20 gal a pop) of gas with that money. 38 tanks, 300 mi/tank, 11,400 miles.
In short, I don't think it's worth the money. I would do it anyway, but it doesn't seem worth it. You have to compromise on both sides; less than stellar acceleration, and driving at a little higher RPM on the highway. That being said, if taking a lot of strain off the engine is worth it to you, then it's worth the money.
Old Dec 18, 2008 | 01:34 PM
08SaharaM6's Avatar
With 37's 5.13's would be a good fit for your Jeep. Not just for gas reasons, your truck will labor more with the lower gears. In every aspect the gear change is definitely worth it.
Old Dec 18, 2008 | 06:24 PM
Thanks a lot for the last two responses. Very Helpful!
