Another spacer question
Searched and searched can't find the answer.
Do I need wheel spacers if I'm running the stock 17" wheels with a 2.5 teraflex BB with stock 17" sra's?
I know I need them if running larger and taller tires but that isn't going to happen for a long time.
If your going to run the stock tires and stock Sahara 17 inch. I would say NO.
But like you said if your going to a wider tire then yes you will need spacers or get a aftermarket rim and you will be good. I'm running 35x12.50x17 and purchased aftermarket rims and im not running them.
