Another Suspension Question
Old Jun 9, 2009 | 04:32 PM
JohnnyRubicon's Avatar
Default Another Suspension Question
I know that there a ton of threads on these sort of topics, however I have somewhat of a unique situation so I am just looking for some quick feedback. Currently I am running a 1.75” spacer in the front only to deal with my rake and added weight from my front bumper. I recently installed a winch and the rake is back. In a few weeks I’ll be putting in a heavier steel back bumper and mounting my high lift extreme on the rear as well.
With these additions I will have roughly an additional 150lbs in front and 100 in the back. Do you guys think I can get a way with running a 2” spacer up front and a 1” in the back, without running new shocks? It would be a temporary solution, 6 months or so, at which point I will be upgrading to a full suspension lift.
With the 1.75 spacers I have had only minor rubbing issues so I am guessing that the front won’t be that big of deal. Just wondering if I start messing with the rear, will I have issues with the rear sway bar rubbing brake lines, etc. Thanks
Old Jun 9, 2009 | 05:02 PM
nangulator's Avatar
It may be time to start thinking about a coil spring lift now instead of spending time and money on more spacers
Old Jun 9, 2009 | 05:20 PM
09rubicon's Avatar
If its only temperary I say leave the 1 3/4 up front and throw the daystar 3/4 in the rear. It will sit level and it is a proven fix (cheap too). If you start thinking 2" in front 1" in rear you are going to end up going through several spacers (and the cash you spent on them) to get it level. Then you can get the TF 2.5" coil lift in a few monthes and have no more problems!!
Old Jun 9, 2009 | 05:29 PM
nthinuf's Avatar
I'd say wait until you actually have the new 250 lbs on the jeep to see how it sits, before even thinking about new spacers.
And if you rub a brake line - move it...
($5 at home depot will drop the line and relocate it back under the frame rail)
Old Jun 10, 2009 | 08:50 AM
Yeh I'm picking up the bumper on the 19th so, I will def wait till then. Then I'll post some pics and see what you guys think I should so.
I am scared of going with the all out suspension right now because I know it will have a dominio affect on me. First I'll put the lift in and then it will be...
...Tires
...Wheels
...Tire Carrier
...Gears
Old Jun 10, 2009 | 08:51 AM
Oh yeh then probably....
...CAI
...CatBack
...Programmer
Old Jun 10, 2009 | 09:13 AM
nthinuf's Avatar
Get the programmer with the tires/gears
