Another tire question
I have a 11 Sahara 4dr with 18 x 9 fuel hostage wheels with 4.5" back spacing. Could I run a 35 on stock height. Looking to do a RK 2.5 max travel end of August but might have a deal on some tires early and we all know how hard it is to look at a mod just sitting around.
It is possible. But unless you have aftermarket bumpers to will rub pretty hard on your air dam (which can easily be taken off) . If you don't have flat flares you will also rub really bad when flexing but normal driving should be OK. also with no lift make sure and check for clearance of the back pinch seem. Other than that you should be fine. Wheel spacers should also help..
