Another will it fit...
Old Aug 6, 2013 | 10:40 AM
Charlie Harper's Avatar
Default Another will it fit...
Hey Guys
I have read the wheel and tires sticky and still am not sure what i am going to need, so...
--I have a 2013 Unlimited Rubi
--I have the TaraFlex leveling kit (spacers 2" front 1" back)
--I want to use my factory 17" wheels
--I want to install and run 305/70/17 tires
Will I need wheel spacers or longer bump stops?
Will I need to trim anything?
Or should I just go with 285/70/17
Thanks for your thoughts
Old Aug 6, 2013 | 11:23 AM
karls's Avatar
You should need wheel spacers and the trimming/ bumpstops will depend on what you do with the jeep. Some people need extended bumpstops on stock suspension, others don't. Your usage will dictate that.
Wheel spacers are merely for the width of tire. If you go with a tall and narrow tire then you're set without them, but take the 'spacers are scary' with a grain of salt. For every poor opinion you hear on them there are a thousand untold success stories.
Sent from my Droid4 and Jkfreaks.com
Old Aug 6, 2013 | 11:28 AM
blue project's Avatar
Originally Posted by Charlie Harper
Hey Guys
Definitly going to want wheel spacers. I ran the Terflex leveling kit with 285/75/17's (34") and I broke my tires would hot my fenders in the rear. I had to replace all the fenders clips because of this. I would run the 285/70's and you shouldnt have a need for different bump stops or trim anything.
Old Aug 6, 2013 | 11:42 AM
JK Inspired's Avatar
Do not run wheel spacers
Old Aug 6, 2013 | 11:44 AM
285/70 will be fine on stockers and the TFLKIT
Old Aug 6, 2013 | 11:48 AM
Ryan0260's Avatar
Lol. Care to explain??
Old Aug 6, 2013 | 11:50 AM
Ryan0260's Avatar
Hey Guys
I say go with what you want. If you want the bigger tire, make the necessary modifications to accommodate them. Don't settle for something that you ultimately won't be happy with.
Old Aug 6, 2013 | 12:45 PM
JK UNLIMITED's Avatar
Seriously ?!? RUN WHEEL SPACERS they make the JEEP look bigger and give you a wider track which gives you better stability, especially on off camber trails. I have personally been running wheel spacers/adapters for 20+ years on everything from SCCA race cars to trail rigs and daily drivers and never had a single problem just torque them with red Loctite and you are good to go and check them every other oil change when you rotate your tires. You will need the clearance to run those tires otherwise it will rub on your front track bar at full lock when turning and you should get extended bumpstops to prevent ripping your fenders off if you flex her out on the trails and you might have to trim your pinch seams and possibly your front air dam...good luck!
Old Aug 6, 2013 | 02:01 PM
Ryan0260's Avatar
A big X2 on this.
Old Aug 6, 2013 | 02:13 PM
r3cluse's Avatar
Out of morbid curiosity, if you use loctite and re-torque later on doesn't that break the loctite bond?
