Any concerns with running 35's on a 30 front????
I have an 09 jk x that I'm currently running 305/70-16's on, its about time to get new tires and really wanna move up to 35's. Wondering if anyone knows of any mods that may help out the stock 30 up front. keep in mind this is a DD and primarily street driven, wheeled every once in awhile unfortunately, haha. Any input would be great, thanks!
U will probably need to get sleeves and gussets for the front axle. You can get them from offroadevolution.com. you will also need someone to weld them on for you unless u can weld. Then u can.go wheeling as long as Ur not heavy on the throttle while rock crawling. Then u can buy aftermarket axle shafts from superior,g2, ten factory, or alloy. Down the road u can save up and get a prorock 44 from dynatrac or even the prorock 60
I agree with Ryan, get the gussets maybe sleeves but don't put a lot of cash into it if it won't hold up with sleeves and gussets you will need a stronger axle if holds up the 30 is all you need and run with it.
