Any FT BB Comments
Old Jun 3, 2007 | 06:16 AM
kb7our's Avatar
Default Any FT BB Comments
Considering the FT BB 2" kit. It does not appear to come with a brake line relo bracket - is one needed? Also, how would the ride differ between the hydraulic vs. gas monotube shocks? Any other comments on this kit?
Old Jun 3, 2007 | 07:25 AM
wayoflife's Avatar
JK-Forum Founder
This is a really good kit that will lift your Jeep 2" and is designed to level out your Jeep's factory rake. With just a 2" lift (1.5" actual height in the rear), brakeline relocation brackets are not needed. As far as shocks go, the M-Force gas charged monotube shocks provide a superior ride over the hydros and if you can afford it, I would highly recommend them
Old Jun 3, 2007 | 09:21 AM
kb7our's Avatar
Guys I appreciate all the input everyone provides on this forum. It is really appreciated by people like me contemplating their first small lift. I'm going to run 33's (Cooper's likely) probably on factory Saraha 18" rims with 1 inch spacers (terra?). I like the idea that the Skyjacker lift has new coils but still trying to decide which route to take.
What would be a good quick disconnect set to go with the FT BB?
Old Jun 3, 2007 | 10:42 AM
2K1TJ's Avatar
As mentioned, the brake line relocation bracket isn't needed, but if you insist, one can be easily made.
I like my FT BB, although I had one of the earlier kits that I'm pretty sure is 2" front and back. I'm adding a 3/4" spacer to fix that though. I'd rather raise the front than lower the back to level it.
