Any tips
Old Nov 9, 2011 | 06:26 PM
bjohn573's Avatar
Default Any tips
Just bought a TF 2.5" coil lift. I'm going to install it myself. Any installation tips would be greatly appreciated.
Old Nov 9, 2011 | 09:18 PM
nthinuf's Avatar
Go down to the write-ups area. Stickied at the top is an index. Any of the lift installs will help, as they all use pretty much the same steps. Jack up a corner, disconnect some stuff, remove the coil, install the new coil (or the old coil with the new spacer), reconnect some stuff, move to next corner, repeat. Not difficult, just a little time consuming if you have never done it before. A tall floor jack and a couple tall stands are a big plus. Air tools are a big plus. Access to a lift is a big plus. A post in the Staging Area offering beer and pizza could turn out to be a huge plus.
Old Nov 9, 2011 | 09:19 PM
pcmasten's Avatar
Veteran: Marine Corp
Don't rely on the template without measuring and re-confirming the position of the hole for the rear track bar.
Old Nov 10, 2011 | 12:06 AM
Xman4602's Avatar
They new kit has a relocation bracket. No drilling required.
Old Nov 10, 2011 | 12:08 AM
Xman4602's Avatar
The front passenger side coil is a pain in the a$$.
