Arb air compressor help!!
Old May 9, 2011 | 04:10 PM
Michiguy's Avatar
Default Arb air compressor help!!
Installing an arb high output air compressor and have followed the write up to a T. Does not mention red/yellow and blue wire on the connector line for the switch. Switch and compressor wont work. I dont know why. Any thoughts?
Old May 9, 2011 | 04:49 PM
stockrubi's Avatar
This is one of the comments left on WOL's write up. I think this is what you are looking for. Worked for me.
Good luck and you will love it! My favorite mod yet!
Brett May 23rd, 2010 10:16 am
I had the same issues about the ignition and light wires, so I grabbed my handy dandy Fluke multimeter and took myself to school.
Here's the answer:
First remove the center console bezel to gain access to the wiring loom.
Switched Power:
Use the included scotch lock connector to connect the red-yellow wire into the blue-violet accessory power lead that runs to the cigarette lighter connector. Note: do not tap into the aux power port on the passenger side. it is always on.
Illumination Dimmer Lead:
Use the included scotch lock connector to connect the blue-white wire into the orange-beige ilumination power lead that runs to the square multi wire connector that attaches to the AC/Heat controls.
Straighten up all the wires so they are neat and out of the way, button it up and be prepared for a bit of compressor noise.
This worked for me on a 2010 Rubi...I'm not making any guarantees. Splice into your shiney new JK's wiring at your own risk.
Brett
Old May 9, 2011 | 04:51 PM
nmwranglerx's Avatar
check the link below and go to post 131 (last page):
https://www.jk-forum.com/forums/show...air+compressor
good luck, you're almost done!
Old May 22, 2011 | 06:57 PM
wvxlt's Avatar
I have a 2011...don't see an orange/beige wire...I have orange/white and pink/yellow...help!
