ARB bullbar on a 2012 questions
Old Jul 31, 2023 | 04:23 PM
cs641's Avatar
Default ARB bullbar on a 2012 questions
Bought a bull bar used and it did not come with the "packers". It's a bolt and a sleeve that appear to be for side reinforcement on the 2010+ JK's. How important are these? They look easy enough to fabricate but if not needed then won't bother.
I have the bumper mounted but wanted to figure this part out before I put recovery loads on it.
Old Sep 18, 2023 | 07:19 PM
ivan2001ve's Avatar
Hard to explain how they work. in case of impact the bar will be push back. They help to keep the bar in position so.it does not bend towards the hood. See this video from TJM another Australian manufacturer that uses the same concept you will see how the packers work
Whoever installed the bar was just lazy, I would also check if they installed the crush cans
Old Sep 19, 2023 | 09:51 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
I would say just from the pictures of reduced mounting hardpoints that you will need to be extra careful if you intend to tow or winch from the bar itself. Remember a bar is ony as good as the mounting points and what it is attached to. You could simply get creative and attach it using some thought and adaption methods. Like some HSS square steel spacers with bolts through them to through the chassis for starters. Not everything is bolt on perfect that is why there are welders and steel cutters in the world.
