ARB Compressor Install
Old Apr 2, 2009 | 08:10 PM
cojk's Avatar
Default ARB Compressor Install
Hi guys, installing the ARB compressor for tire inflation only, no lockers yet. Anyone know if it's necessary to install the pressure switch to the compressor at this time or can I just install the coupler for the tire hose directly?
Thanks...
Old Apr 2, 2009 | 08:17 PM
SteelMastiff's Avatar
I would guess that you should install the pressure switch; it will turn the unit on and off... If you have a tank than it is a must do regardless.
Old Apr 2, 2009 | 09:26 PM
cojk's Avatar
Default arb compressor
Thanks for the tip.
Old Apr 3, 2009 | 04:55 AM
Preciousmetal's Avatar
I just installed mine and if I was you put that switch on I feel it important or you could damage your new compressor.
Old Apr 3, 2009 | 05:28 AM
Littlejon's Avatar
The pressure switch is what turns it on and off when it is running and it hits the desired PSI. If you don't run it you compressor would be running constantly, and I don't think this is a 100% duty compressor you would fry the motor pretty quick.
Old Apr 3, 2009 | 06:43 PM
Heyspike's Avatar
Where did you guys mount your compressors? I have mine mounted inside the front bumper.
Old Apr 3, 2009 | 06:46 PM
cojk's Avatar
Got it install thanks for the help. I got mine from Northridge 4x4 with tire inflationkit and bracket. Bracket mounts to the brake booster.
Old Apr 3, 2009 | 07:17 PM
Heyspike's Avatar
Do you have any photos of that? thanks
Old Apr 3, 2009 | 07:31 PM
cojk's Avatar
Default arb compressor install
I don't have pics yet, but check out this thread from the vendor forum, lots of pics.https://www.jk-forum.com/forums/show...arb+compressor
Old Apr 3, 2009 | 08:19 PM
Suffolk JK's Avatar
I ran the pressure switch. Turns the compressor off after 2 seconds of turning it on since it builds full pressure that fast. If it wasn't on, the compressor would continue turning. Add the pressure switch off a t-fitting. The other end, thread in a quick coupling.
I used 2-Tracks Engineering bracket that bolts to the master cylinder/brake booster area.
