ARB Locker not Locking
Old Dec 8, 2009 | 03:49 AM
jkerr's Avatar
Default ARB Locker not Locking
I have an ARB locker in my rear D44 and it isn't locking in consistently. The air compressor will run continuously and sometimes it will eventually lock in and other times the compressor runs non-stop. I've checked the line from the compressor to the pumpkin and the fittings are tight and the line is in tact. The problem seems to be worse when it's cold. Any ideas what I can check? Thank you!
Old Dec 8, 2009 | 05:53 AM
wayoflife's Avatar
JK-Forum Founder
based on what you are saying, you clearly have an air leak somewhere along your air line. if your fittings and o-rings really do check out, you definitely have a leak somewhere else.
Old Dec 8, 2009 | 06:34 AM
jkerr's Avatar
I checked the o-rings and the line and all looked ok, but it is certainly possible that I missed something. The locker was locking fine when I was testing. I will check it again when the compressor is running continuously. How likely is a leak inside of the ARB unit itself? I haven't pulled the differential cover as of yet. Is there an easy way to test the internal unit without pulling it apart?
Old Dec 8, 2009 | 07:04 AM
wayoflife's Avatar
JK-Forum Founder
if the compressor keeps on running and the locker is leaking in side, the air will make its way out one way or an other. i would check your axle breather as you should be able to feel/hear/smell it coming out there.
Old Dec 8, 2009 | 02:00 PM
jkerr's Avatar
Originally Posted by 426 HemiJK
I had a problem with my ARB leaking and I could hear it leak out the air breather as WOL said. It turned out to be an "O" ring inside the diff. It wasn't that big of a deal to fix either. I had just recently had the ARB's put in so I took it back to the install shop and watched them do it. I know if I had the parts I could easily do it myself if I ever had that problem again.
I tested it tonight and the air is coming out of the differential breather tube big time. It does act like an o-ring. It is free flowing when it is cold. It will hold when the diff warms up, but the compressor has to run every minute or so to keep it locked in.
The shop that installed the gears/lockers is out of town. I may dig into it myself. Does anyone have a diagram of where the o-ring is? Thank you!
Old Dec 9, 2009 | 07:57 AM
tcodtj's Avatar
Go to arb's web site. They have a diagram of it.Then give them a call they're vary helpfull.
