ARB rear install
Old Sep 23, 2012 | 07:46 PM
last5liter's Avatar
Default ARB rear install
My jeep already has an ARB hi outout compressor under the hood.
Was wondering how hard is it to install a rear ARB locker into my D44?
I'm not looking to change gear ratio, so I would only be pulling the carrier not the pinion gear.
Do you need a case spreader?
What are the odds the backlash will change?
How long does this install usually take?
Anyone have experience with the locker install only, not with a gear swap?
What would be more benificial, a aussie locker up front or an ARB locker in the rear to replace my limited slip?
Old Sep 24, 2012 | 10:07 AM
last5liter's Avatar
no one has any thought on this?
Old Sep 24, 2012 | 03:52 PM
Evo1's Avatar
Yes you will need a case spreader.
The carrier bearing preload & backlash will need to be set up as per ARB instructions.
It's aprrox 6-8 hours, adjusting preload requires adding & removing shims.
