Argh. Need new Synergy ball joints again
Old 09-18-2016, 06:04 AM
sea bass's Avatar
I had a set of synergy bj's replaced under warranty last year. Maybe 6 months old?
I do wish there was a permanent solutions to this issue - other than upgrading to 60’s.
Old 09-18-2016, 06:06 AM
sea bass's Avatar
Originally Posted by dahreno
You have some other issue going on causing them to fail. I would call them,last I heard, they claim not a single failure reported and mine have lasted for years on 35's, I live by the Rubicon and wheel every weekend. What do you do with your Jeep ? What size tire are you running ?
Who's claiming not a single failure? Synergy??
Lol
Old 09-18-2016, 06:12 AM
jtphoto JK's Avatar
I had Synergy balljoints, lowers lasted only a year. Put stock back in and it's been over 2 years and they are still tight.
I have heard nothing but good from the TF HD balljoints.
Old 09-18-2016, 07:34 AM
Monte417's Avatar
Just thought I would throw this out there because it could be useful to those wanting to switch out from synergy balljoints. My buddy took out his synergys and replaced them with the teraflex joints only to find out the lowers wouldn't press in tight. I guess the synergys run slightly bigger and increase the diameter of the axle c
Old 09-18-2016, 09:08 AM
Chuck-The-Ripper's Avatar
To caveat off this, Teraflex also makes knurled balljoints which is what you would need.
Old 09-18-2016, 09:10 AM
urmyboyblue's Avatar
I've also heard TF ball joints you have to shave off some material from somewhere. Hence the reason I've not thought about the TFs much.
Old 09-18-2016, 09:24 AM
Monte417's Avatar
That's just it he did get the knurled. Still too loose. He called teraflex and their response was they have been getting calls from guys who did this swap with the same results
Old 09-18-2016, 10:54 AM
karls10jk's Avatar
It's minor grinding on the axleshaft stub from sloppy casting. It's something that should have been done out of the factory and frankly wouldn't be acceptable on a more expensive vehicle.
Old 09-18-2016, 11:17 AM
kjeeper10's Avatar
So what did he do?
Old 09-18-2016, 11:23 AM
Monte417's Avatar
Originally Posted by kjeeper10
So what did he do?
He called quadratec returned the tf and they sent him synergys at no charge
Tf did acknowledge this issue
Quick Reply: Argh. Need new Synergy ball joints again
