Armored Up D30 or upgrade to D44?
Old Apr 12, 2017 | 06:43 PM
urmyboyblue's Avatar
Veteran: Navy
I wheeled my beefed up 30 with an ARB for over a year on 37s and it took 5 mins of a bad angle and POP. Passenger axle shaft gone. ARB...gone. In the end I wish I would've waited, saved, and got my Tera44. This axle is sexy.
Old Apr 12, 2017 | 06:59 PM
Dynatrac's Avatar
Sponsoring Manufacturer
Originally Posted by sundevil
I am about to finish off my next stage of my build:
Will run 37's in about 3 years right now I have 35's.
My next stage was going to put an ARB locker and 4.88 Gears in my D30 with Artec Full Armor Truss Kit.
I have a buddy selling his D44 housing from his Rubicon to me for 800 bucks. No guts just ball joints and axle housing and diff cover.
I think I should be able to transfer a lot of my components over to the new housing and then have the gear shop put the lockers and gears in the D44.
Is it worth it for me to upgrade the housing or is my armored up D30 enough? So far I have paid about 400 bucks to parts/welder total for my D30 C Gussets, control arm skids and Axle truss.
Thanks.
With a D30, even "armored up" is the ceiling. You mention 37s, your D30 even beefed up won't handle that for long, and will certainly be your weak link in the drivetrain on-road and off-raod. With the D30, you will always be limited in the other mods you want to make, and the wheeling you want to do. Someone mentioned before "It'll be fine as long as you keep in mind what's under you" or something to that effect. Why distract yourself on the trail with the constant worry of "will this break my D30?" while you're trying to enjoy yourself? You could even be driving on asphalt, and the right/wrong circumstances could bend your D30. And when that happens, all the money you spent to "armor up" that D30 just got flushed down the toilet.
Here's our advice: since you know the budget you have to spend, give us a call at 714-421-4314 and talk to one of our guys to work up a quote on what a ProRock 44 would cost you. That takes one part of the guess work out.
Next, total up everything you'd spend to beef up that Dana 30, inlcuding the cost of the labor to have those parts installed. Figure on a labor rate of at least $125 an hour, but call your local shop and see if you can get more exact pricing. Then compare the real cost of improving the Dana 30, and see how that compares to buying a ProRock 44, also keeping in mind that the ProRock will add value to your Jeep if you ever decide to part with it. We're pretty certain you'll see the numbers don't lie, and for the cost of everything involved with that D30 improvement, the difference isn't that much between your D30 and just buying a much stronger ProRock 44 axle assembly that you won't have to worry about. And an axle assembly that will give you lots of room for future mods and improvements such as larger wheels/tires, different gear ratios, lockers, and so on.
In the meantime, check out our website and learn more about the ProRock 44 to help when you give us a call. https://www.dynatrac.com/axle-assemb...k-44-axle.html
Old Apr 12, 2017 | 07:12 PM
sundevil's Avatar
Originally Posted by Hail2Ale
You can get by with an open d30 with 35s pretty well that's what I have. Been running this way for several years now wheeling in rock creek beds and trails. 37s just put a lot of strain on the d30 even with an open diff. Just lock the rear 44 & regear and you are set.
Thanks for your honest opinion I will definitely go that route now since it is my daily. I think by the time I reach 37s I'll have a different vehicle and should be able to go with the Prorock 44 upfront and regear with more crawl orientated gearing as it will no longer be my daily.
Thanks
Old Apr 12, 2017 | 07:14 PM
sundevil's Avatar
Originally Posted by resharp001
I'm not trying to sway you from building or going with a rubi 44, just trying to highlight how close the cost can get to a PR44, but a lot of that depends on labor and what you have to pay for. I tallied up mine in a different thread the other week and I was around $3100 for a Rubi 44 which I regeared, trussed, gusset, LCA and shock brackets, and with Dynatrac BJs. That wasn't too bad cuz I was able to save on labor and I did it over a couple years. I think if you're looking at that cost up front, then it's better to look at something else like a Dynatrac or Currie.
It's always a real conundrum when you start out with a D30 and then realize you need more. I went through the same thing couple years back, and unless you have a really nice slush fund there's no easy answer. I think if that housing would cost you more like $500, building from that would start looking more interesting.
Thanks for the input reshape! Right now I can get ARBs front and rear with new gears for 3200 cash installed with an arb compressor installed from a local buddies shop which is what had me considering locking the d30 to begin with.
I think I will just lock the rear for now.
Old Apr 12, 2017 | 07:15 PM
sundevil's Avatar
Originally Posted by cedarraider
The rubicon 44 is no stronger than the 30. The only thing that makes them better is a bigger ring gear and they are set up for lockers. I've thought about this but will be going with an aftermarket 44 that have bigger and thicker tubes and bigger inner Cs. You can get a loaded 44 with an arb, gears, axles, ball joints set up and delivered for about $4400.
Yeah thats what I read too I really like how the dynatracks don't seem to need a truss or sleeves for my intended use.
Old Apr 12, 2017 | 07:17 PM
sundevil's Avatar
Originally Posted by tarpon4me
A Dana 30 can be fine if you set it up properly and remember what's under there when you're wheeling. I wouldn't go to much taller numerically ring and pinion wise in a 30 than maybe 4.56, which is what i'm running with 35's. Also, keep it at a 35, and try a Truetrac. I'm running TT's front and rear and they are great and do their job. Much more forgiving than a full locker, especially for that dana 30, and they will amaze you with what they can do.
Thanks I think I'll have them throw one of those upfront for now in the D30 while I lock the rear sounds like a good compromise a lot better than having to throw away a 900 locker once I go with the new 44 upfront.
Old Apr 12, 2017 | 07:19 PM
sundevil's Avatar
Originally Posted by Dynatrac
With a D30, even "armored up" is the ceiling. You mention 37s, your D30 even beefed up won't handle that. With the D30, you will always be limited in the other mods you want to make, and the wheeling you want to do. Someone mentioned before "It'll be fine as long as you keep in mind what's under you" or something to that effect. Why distract yourself on the trail with the constant worry of "will this break my D30?" while you're trying to enjoy yourself? Hell, you could even be driving on asphalt, and the right/wrong circumstances could bend your D30. And when that happens, all the money you spent to "armor up" that D30 just got flushed down the toilet.
But, here's what we feel is the best advice, since only you know the budget you have to spend. Give us a call at 714-421-4314 and talk to one of our guys to work up a quote on what a ProRock 44 would cost you. That takes one part of the guess work out.
Next, total up everything you'd spend to beef up that Dana 30, then add in the cost of the labor to have those parts installed (figure on a labor rate of at least $125 an hour. But call your local shop and see if you can get more exact pricing) and then compare the real cost of improving the Dana 30, and see where you're at compared to buying a ProRock 44, also keeping in mind that the ProRock will also add value to your Jeep if you ever decide to part with it. We're pretty certain you'll see the numbers don't lie, and for the cost of everything involved with that D30 improvement, you'd be a small sum away from just buying a much stronger axle assembly you'll never have to worry about. And an axle assembly that will give you lots of room for future mods and improvements such as larger wheels/tires, different gear ratios, lockers, and so on.
This is so awesome hearing from the actual company! I'll give you guys a call tomorrow morning. This hobbies really hard on a college budget. I'm solidly convinced from this thread that I should go with the ProRock 44 and stop throwing money at the D30.
Thanks Dynatrac!
