ATX SLAB Beadlock install questions
Old 06-20-2016, 05:59 PM
  #21
scooby snacks's Avatar
Originally Posted by jedg
So I picked up a set of slabs... I'll be doing my install next week. Did you install the TPMS sensors or just ditch them?
Where'd you get yours from J?
Old 06-20-2016, 06:05 PM
  #22
jedg's Avatar
A fellow on here had them posted... just inside VA north of Raleigh. Went up there last weekend and got them. I have them disassembled in the garage right now. Just put Dynatrac ProGrips on tonight. Will have a local shop dismount my current KM2 and then I'll mount them on the slabs myself by the weekend.
Old 06-20-2016, 07:01 PM
  #23
miraclemax's Avatar
What would be a good psi to run in these on trail? Lowest I have gone on my old rims that were normal beaded rims, was 15.
What would be a good psi to start at?
Old 06-20-2016, 08:32 PM
  #24
JKZinger's Avatar
Originally Posted by miraclemax
What would be a good psi to run in these on trail? Lowest I have gone on my old rims that were normal beaded rims, was 15. What would be a good psi to start at?
I run mine at 8 psi on hardcore trails.
Old 06-21-2016, 06:19 AM
  #25
jordy's Avatar
10-12 in mine will pretty much cover whatever I want to do. If we're going especially gnarly crawling, 6-8 makes it into a whole new machine.
Old 06-21-2016, 08:06 AM
  #26
miraclemax's Avatar
Just checked all the bolts at about 85 mile since install. I checked them at 21#. Not a single one had moved. All were perfect.
I have been to 60-65 mph, and don't notice any vibration in the wheel. I guess maybe I should try 70-80 mph as well and see.
But would not having these balanced at a shop affect anything? Like tire wear etc? They seem to be running fine!
Old 06-21-2016, 05:27 PM
  #27
Awesome... post pics when you get them mounted... I'm getting the itch!!
Old 06-21-2016, 06:17 PM
  #28
mhockey9090's Avatar
I run 5-6 psi on the trails, for rock crawling at least. If its dirt trails and higher speed stuff, ill keep it around 12 psi.
Old 06-21-2016, 07:54 PM
  #29
JKZinger's Avatar
Just checked all the bolts at about 85 mile since install. I checked them at 21#. Not a single one had moved. All were perfect. I have been to 60-65 mph, and don't notice any vibration in the wheel. I guess maybe I should try 70-80 mph as well and see. But would not having these balanced at a shop affect anything? Like tire wear etc? They seem to be running fine!
I have had mine on for 4 years and have never balanced them. Only had to retorque a couple of the bolts that whole time.
Old 06-30-2016, 06:30 PM
  #30
jedg's Avatar
So reading this I decided to run them without balancing and see what I thought. I'm amazed that they don't need balanced. I run up to 80mph and no vibrations.
Quick Reply: ATX SLAB Beadlock install questions
