View Poll Results: Do you like your Aussie Locker
I am happy with my Aussie Locker
11
100.00%
I am not happy with my Aussie Locker
0
0%
Voters: 11. You may not vote on this poll
Aussie
Old Feb 6, 2011 | 06:39 PM
Rafi's Avatar
Originally Posted by jwhitehorn
The only time I notice mine (in a bad way that is) is when I am making tight turns. Think parking lots, parking garages, etc. Then, unless I finesse the gas and gearing, I feel the "clunk-clunk" of the locker.
exact same thing here. only in super tight turns i hear/ feel a clunk
Old Feb 6, 2011 | 06:53 PM
u-joint's Avatar
Originally Posted by animated_robot
I'm ordering the Aussie for the JK Dana 30 so no worries. When I add the diff oil, is there some type of additive from the dealership that also needs to be put in?
There is no special additive that you will need, just regular gear oil.
Although I did move up to Mobil 1 75W-140 synthetic gear oil... but I figured, after paying good money for gears and a locker, I might as well spend good money on oil too
Old Feb 6, 2011 | 06:54 PM
opdsgt's Avatar
I've been driving my JK with a front D30 Aussie all winter and we get plenty of snow here in the Midwest. It's well behaved. You can provoke the Jeep to act up in turns with an intentionally heavy right foot, but if you drive prudently you'll never know it's there.
Aussies are quiet, strong, and easy to install. And on the trail? No comparison in the more difficult venues; two lockers dominates over a rear locker alone.
Old Feb 6, 2011 | 06:59 PM
u-joint's Avatar
Thats been my experience with the Aussie this past winter. In Oklahoma we get our fair share of snow and ice, and (like you said) if you drive as the weather dictates, it shouldn't give you a lick of problems.
Old Feb 7, 2011 | 06:43 AM
Dynatrac's Avatar
Sponsoring Manufacturer
It isn't a bad option but definitely consider upgrading your axle shafts. I've lost count of how many broken D30 JK axles I've seen in just the last year.
Old Feb 7, 2011 | 07:38 AM
Rhino64's Avatar
Wouldn't it be better to damage a shaft than damage the ring gear?
Old Feb 7, 2011 | 07:41 AM
Dynatrac's Avatar
Yes. However, I've seen the stock axles break with so little effort that I'd want them anyway.
Old Feb 12, 2011 | 06:46 PM
Tgoods 09 X's Avatar
I pulled the trigger,
Aussie
C Gussets
EVO Sleeves
and Solid Cover
I will run my stock axles untill I can afford to get a set of chromoly shafts
Thanks for the input!
Old Feb 16, 2011 | 05:09 PM
animated_robot's Avatar
Aussie
C Gussets
EVO Sleeves
and Solid Cover
Tgoods how did the install of the Aussie go? Did you do it yourself? any problems?
Old Feb 16, 2011 | 11:56 PM
Rhino64's Avatar
X2 on that question.
