auto to manual
Ok time to junk auto nothing but problems should have bout stick does and one have a list of parts needed i have seen some where on here but no its no to bad since most off the parts are bolt on just have to get new tranny pcm and all the little things thanks if any one can help
B
If your looking for lower gearing out 4 wheeling just put in a Atlas or something, much easier and much better use of modding $$$'s and time.
If it's freeway issues, then change your gearing to 4.88,, 5.13, etc.
I'll I've had all 3 of my past Jeeps with Manual Transmissions. I decided to get an Auto this time because of the endless low range without stalling, and my 4/1 Rocktrac transfer case. Even with 35's and 4.10's in 4 low 1st gear, it is plenty slow. I Love it, the freeway, at 75, I might be better with 5.13, but I can live with it as is for now.
I'm sure there are reasons for a Manual (I hear rock crawling is one), but it better be a really good reason as all the above will make your Jeep rock!.
After all that if you decide you still need a manual, you can still use all these wonderful mods!
Mod on my Friend!
Mod on my Friend!
I have re geared have alot of issues with tranny temp every time i off road trans fluid cooks was great at first as with many all my previous jeeps where stick and i never had a problem.
