automatic to manual
Old Jul 21, 2012 | 12:31 PM
billyd665's Avatar
Default automatic to manual
Does anyone have a write up for swapping a automatic transmision to a manual???
Old Jul 21, 2012 | 01:53 PM
hypeiv's Avatar
Never heard of it being done... For the price of parts and labor you are better off trading in the auto and buying a used manual.
If you are looking for performance your better off spending money on gears
Old Jul 21, 2012 | 03:26 PM
crazymike's Avatar
My brother has done it on a car (celica). It's a major pita.
It's not just swapping transmissions. There are so many things like mounts, programming, electronics, etx. And that was an older car.
Old Jul 21, 2012 | 07:43 PM
Ryan0260's Avatar
X2. Sell it and get a manual
Old Jul 23, 2012 | 08:15 AM
billyd665's Avatar
Im just looking to do a complete swap. had to get an auto due to going on deployment and wife didnt know how to drive a standard. now that im back, i have a opertunity get a manual transmission for cheap. just wondering if its more trouble, then its worth.
Old Jul 23, 2012 | 08:42 AM
Chronotripper's Avatar
Veteran: Marine Corp
It really is an entirely different beast. I just got a Hemi put in mine and went from a manual to an auto, and there is a TON involved. Besides switching out the transmission, you will have to find all the cosmetic stuff: shifter, center console piece, and clutch pedal/equipment. That's the minimum I know about and there may be more; maybe a new wiring harness? Also, you will have to bring it to the dealership and get the computer reflashed as well.
Ultimately, unless you are paying for an engine conversion then it really isn't worth the cost. You may be able to save the money by doing all the work yourself, but I would say you are better off trading it in. Depending on what you trade it in for, you might not need to pay much of a difference since an automatic is more expensive.
Old Jul 23, 2012 | 08:46 AM
elitecontrol's Avatar
I've seen/ done a few on some Hondas, honestly just spend the money on more mods. There isnt an advantage to standard over auto. More of a preference thing.
For the swap is say you need a donors rig to do it right. A lot of cap to change.
Trade it in or live with auto.
Old Jul 23, 2012 | 09:16 AM
Al-Raisi's Avatar
Hi,
am planning a hemi conversion and so confused which transmission I should go for. currently am driving manual but I read in many threads that Auto is better with Hemi and I don't know why!!! Can you plz share your experience here and share the reason why you went from Manual to Auto.
Regards
Old Jul 23, 2012 | 09:24 AM
JKingAround's Avatar
Originally Posted by Al-Raisi
Hi,
Regards
The manual used in the switch is discontinued and real pricey for rebuilds. And was told by my buddy that's a Transmission guy that it's a weak tranny.
Old Jul 23, 2012 | 03:00 PM
fftri's Avatar
A fellow club member did the opposite after his manual trannny died.
He got the auto tranny, brake pedal, center counsel stuff, shifter, and two wiring harnesses.
The he had the dealership flash it.
I had my JK there to check part numbers and to reference because it is an auto.
I do not recall how many hours were involved, but as others have said it is not a simple weekend job.
It took a couple of meembers, one who is a mechanic at least a couple weekends to get everything totally working in harmony.
The wiring harnesses are a royal PITA to get out, especially if they've been in for a while.
A couple connectors needed a contortionist to get to and to get to release.
They were doing the swap on a lift that made it a bit easier.
