Axel Shafts? Which ones?
So after my break this past weekend i am in the market for a set of shafts
i DO NOT want RCV's because i am scared i will grenade my differentials
Anyones suggestions and opinions are great
Well even though you say you dont want RCV's they would be my choice.
Second choice would be Ten Factory Chromoly front shafts and CTM U-joints.
We have sold a ton of the RCV's and nobody has called back and told us they grenaded there diff. I am putting a set of RCV's in my 4 door next week.
EDIT: For the rears the Evolution series axles from superior.
David
David
i mean what can break on an RCV besides the ring and pinion
i dont know i just feel like that could be asking for trouble
Most the time when the Darn u-joint breaks it takes out both axle shafts " inner and outer" and a Ball joint or Both.
I have posted this many times in the past but I dont see a reason to build a axle with a weak link. We rarely see a ring and pinion break. Does it happen sure. But the ring and pinion is really strong.
David
I would think that after the axles, the drive shaft would be the weak link. Just don't build 1350 driveshafts along with the RCVs.
I asked my local shop this question about the weak link. Their theory was that even with RCVs the weak point will be the axle shaft itself. That'd you probably break the shaft off at the splines before you start exploding r&p or poping 1310 joints.
But that's all theory....
