Axel sleeves and gussets duarability
Old Jan 28, 2011 | 02:40 PM
MikeReo's Avatar
Default Axel sleeves and gussets duarability
Has anyone sleeved and gusset'd their front Dana 44 and had problems. Not talking about ring & pinion, shafts or any internal components. I want to know if Anybody has sleeved their axel and since bent the housing or c's. What are you using? What size tires and have you had any issues? Any opinions on ineer verse outer sleeves?
Old Jan 28, 2011 | 02:46 PM
AveryR's Avatar
I have gussets on mine and I'm running 40 inch toyo mts and will be installing sleeves sometime next week so ill let you know about those . The gussets are holding up fine and the axle does not look like it has been bent whatsover but then again I haven't been doing much wheeling all because I don't have sleeves and like to play it safe. Also I would go with inner sleeves since I've seen more people running them then the outer ones.
Old Jan 28, 2011 | 02:56 PM
MikeReo's Avatar
Wow..40's? yeah i'd wait till it was sleeved. What gussets did you go with?
Old Jan 28, 2011 | 02:58 PM
nthinuf's Avatar
I think there was one in this thread. The sleeves just moved the shatter point to another part of the housing.
https://www.jk-forum.com/forums/show...t-Axle-Housing!!
Posts 35 and 38 talk about it. The sleeves moved the break point from the ca mounts area to the diff.
Old Jan 28, 2011 | 03:08 PM
wayoflife's Avatar
JK-Forum Founder
before destroying the inner workings of our dana 44, we had off road evolution gussets installed and NO sleeves and saw no additional bending of anything. we were running 37x13.50 toyo mt's at the time and had about 65,000 miles on the axle. it was only last year that i had personally seen multiple housing breaks and before then, i never thought they were needed - at least, with all the torture we put our axle through, our housing never broke. with over 300,000 JK's out there today, i still think housing breaks are far from common but, having a set of inner sleeves installed is good insurance to have.
why? you're more likely to break an axle shaft than the housing any day of the week. housing breaks are NOT common.
Old Jan 28, 2011 | 03:16 PM
wayoflife's Avatar
JK-Forum Founder
yeah, this was on blazer4949's jk and it happend on our rubicon run. fortunately, he did have inner sleeves and it helped keep his axle together even after seeing signs of breaking. he now has a dynatrac prorock 44 and, if you were to ask him, he would tell you that he wouldn't have wasted his money beefing up his 44 and would have gone right to the prorock had it been available sooner.
Old Jan 28, 2011 | 03:17 PM
AveryR's Avatar
ORE. Teraflex makes some as well. Both great products. Both do the job efficiently.
Old Jan 28, 2011 | 03:24 PM
MikeReo's Avatar
Just re-read the thread you guys are refferring to. This is the decision im trying to make i guess. These axels seem to go for pretty decent $$. I have one sitting in my garage ready to go but i have been kicking around the idea of selling it and putting the funds towards a better axel. I'll be running 37's.
Old Jan 28, 2011 | 03:32 PM
wayoflife's Avatar
JK-Forum Founder
for the amount of money it would take to build up your factory 44, i personally think you would be much better served to just save up a bit and get a prorock 44.
Old Jan 28, 2011 | 03:54 PM
MikeReo's Avatar
Anybody know what a pro-rock 44 with an arb is going for? Theres no pricing on the website
