Axel swap
Old Apr 29, 2012 | 06:27 AM
slowburn's Avatar
Default Axel swap
Need info on rear and front axel. Swapping out front And rear. I have stock rear with ten chromoly with E locker wanting to put in Dana60 and a Dynatrac 44 front with E locker and Dynatrac ball joints with 4:88. Want to switch to ARBS both front and rear. Was told that the front Dynatrac with my E locker will not except a ARB. So looking at Currie and TeraFlex don't have much info on TeraFlex any info would be great
Old Apr 29, 2012 | 06:51 AM
Dynatrac's Avatar
Sponsoring Manufacturer
I'm not really sure what you're saying here but I THINK you're saying you have a PR44 up front with an ELocker. ELocker is a trade name for an Eaton electric selectable locker it is NOT the factory locker. The Factory Rubi electric selectable locker is a Tru Loc. If you have an Eaton ELocker can replace it with an ARB. If you have a factory Rubi Tru Loc, ARB offers only a 35 spline unit for replacement. The 35 sp ARB unit will require new front axle shafts.
The internal dimensions of the factory 44 housing are copied in the PR (and I assume in the Tera housing too). The factory locker is unique and a common 30 sp ARB (or any other common diff) will not fit.
