Axle
So Here's my issue I installed a TF 2.5 lift with 35s and then put on some RK adj lcas and wasn't sure how long so eyeballed it. Well it messed up the angle of the axle which then messes up my front driveshaft, just ordered a new HD one. So last night I tried to re adjust my lcas to proper length(23 1/8) and the axle was shifted clockwise so I couldn't do that, had to ratchet strap the axle and turn it until I could put the lcas back on to the length I had before(24 3/8). How can I fix my axle? And the LCA'S should be 23 1/8 straight length or curved?
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
Measurement would be center of hole to center of hole, not along the length of the shaft.
Link to RK install instructions with measurements:
http://objects.dreamhost.com/rockkra...STRUCTIONS.pdf
