axle centering question
Old May 30, 2011 | 10:01 AM
rubic0n's Avatar
Default axle centering question
I have a TF 2.5" spring lift with a TF front track bar. The front axle is slightly less than 1/2" off center, and the track bar already as short as it can go. Do I need a different track bar, or does it matter. The Jeep seems to drive o.k. other than a slight pull to the left.
Old May 30, 2011 | 10:35 AM
rubic0n's Avatar
Originally Posted by ECHO
Did you use a relocation bracket on the back? because adding a 2.5" lift will offset the rear axle by 1/4" sometimes even a 1/2"
Yes, I used the bracket that came with the kit on the back, and a JKS reinforcement bracket on the front, but the front bracket uses the stock mounting point for the track bar.
