Axle ratio on Superchip
I just installed 5.13 on my back axle only. I will be fine as long as i don't put it on 4x4. I am having the front installed next week.
Question I have is on my Superchip programmer. Can I put 5.13 on my axle ratio now or so I have to wait till I install the front as well
Originally Posted by pettym
You can do it now, it's only there to adjust the speedo.
It's not going to hurt anything. How is it any different from having it set at 3.73 as is the case right now? I have a manual so my superchips doesn't adjust any shift points for me, but if you have an auto and teh ratio effects teh shift points, you'd want it set to your drive gear and not your "dead" gear.
That I am not sure of because it didn't matter for me so I didn't really research it. I know there is away to adjust shiftpoints with it, but I am not sure if it is directly tied to the axel ratio or not. Maybe someone with an Auto can chime in or read up on the superchips site/manual about it.
Yes you want to go ahead and set the program for both the Gear's and tire size. It does make a big difference. Shifting and speedo work much better when tuned correctly. Also make sure that when you take it into the dealer for anything make sure that you plug in the superchip and return back to factory settings. if not and they hook their programmer you will be paying a additional fee to superchips to unlock you programer so it will work again.
