Axle Seals
Old Apr 27, 2015 | 12:21 PM
FDHog's Avatar
Default Axle Seals
Is it true that the 13 JK only has outer front axle seals?
I have a leak on the passenger side and was looking up seals and all I can find are outers.
After looking at a schematic, all I see listed are outers.
Old Apr 27, 2015 | 12:52 PM
jnabird333's Avatar
Not true at all.... outer seals are all aftermarket and I consider them voodoo. All front JK axles only come with inner seals from the factory.
Old Apr 27, 2015 | 01:20 PM
Elusive's Avatar
Veteran: Marine Corp
search for differential seals.
Old Apr 27, 2015 | 01:23 PM
jnabird333's Avatar
SYNERGY MANUFACTURING :: Jeep JK :: Synergy Jeep JK/TJ/LJ Front D30/44 Inner Axle Seals
Old Apr 27, 2015 | 04:28 PM
kjeeper10's Avatar
Vet Army
Mopar is using a 2 piece seal in place of the single posted above.
Old Apr 27, 2015 | 04:42 PM
tribulation138's Avatar
When i did my front bjs and ujoints i only saw 1 seal way on the inside of tube?
The rear axle has 2 for each side?
Old Apr 27, 2015 | 05:09 PM
jnabird333's Avatar
The rear axles only have outer seals. The bearings are lubed with the differential gear oil. These seals are on the shafts and have to be installed before the bearings, bolting plate and tone ring.
