backspacing?
Old Nov 14, 2009 | 10:46 AM
sjsperdute's Avatar
Default backspacing?
is anyone running 35" tires on 16x10 with 4.5" backspacing. i was wondering how past the fender your tires are sticking out.
Old Nov 14, 2009 | 01:38 PM
spinlock's Avatar
It will be highly dependent on the tires.
What tire and width are interested in?
Old Nov 14, 2009 | 04:52 PM
RN M OVR's Avatar
If it's a 35" tire, I will assume the width will be 12.50. With that said, 4.5" backspacing is the preferred backspacing for that tire size -- your tire will stick out about anywhere form 1/2" to 1" max outside the fender flare. Trust me, it's very unnoticeable. It also depends on your trackbar -- if one side is sticking out further than the other because of axle displacement.
Old Nov 14, 2009 | 05:47 PM
aldaman's Avatar
What about a rim w/3.62" backspacing and a 35" tire with a 14.50" width? How much would it stick out past the fender? 3" Thanks..
Old Nov 14, 2009 | 08:22 PM
nangulator's Avatar
I have 35x12.5x17s on 17x9 wheels with 5 inches bs, no rubbing issues when aired down, they do stick out about 1/2 inch past the factory flares.
Old Nov 14, 2009 | 08:35 PM
NTXJK's Avatar
Heres mine 16x10 4.5"BS 35X12.50 Nittos old pic but you get the idea Tires stick out about 3 to 3-1/2 inches
Old Nov 14, 2009 | 09:45 PM
aldaman's Avatar
Love that wide stance....
Old Nov 15, 2009 | 05:27 AM
sjsperdute's Avatar
NTXJK.....thanks for the pics. jeep looks awesome. i was worried how far they would stick out. do you have any problems with stone chips or did you up grade to bigger fender?
Old Nov 15, 2009 | 08:44 AM
RN M OVR's Avatar
Hmm... I have 33x12.50 tires on wheels with 3.75" backspacing and they stick out about 2.5" from the fender flare. So that should give you an idea with yours. I think one side sticks out almost 3" because I am still running the factory track bar and have not bought an adjustable one to compensate the axle's shift -- rides fine though!
NTXJK -- I love your JK, very brollic! I don't understand how your tires are sticking out so much with the backspacing you have!? But I do like your wide stance, just interesting how you get so much of a stance -- must be tires
Old Nov 15, 2009 | 07:45 PM
NTXJK's Avatar
Thanks man no rock chips whatsoever just a lot of mud and grim from the road
To be honest with you I think its more than that I just found out today my rear isnt centered and I measured the side sucked in and that was 3-1/2 inches I will center it and get a true number I really think its the grapplers
