backspacing for a 14.50?
Old Feb 11, 2009 | 09:21 AM
BMPJDS's Avatar
Default backspacing for a 14.50?
I have a spare set of 16" crager soft 8's with 5" backspacing. im aware that this wont work but what about 1.25" spacers with them? that would put me at 3.75" backspacing. is that to much or should i give it a go? the tires will be 35 -14.50 boggers.
Old Feb 11, 2009 | 02:57 PM
BMPJDS's Avatar
no sugggestions?
Old Feb 11, 2009 | 03:21 PM
CJtoJK's Avatar
I'm running 14.50s, with spacers I'm at 3.50 BS and it works good
Old Feb 11, 2009 | 03:26 PM
BMPJDS's Avatar
nice looking jeep. always loved the look of the dirt grips.
Old Feb 11, 2009 | 05:34 PM
HUNTER's Avatar
I had a set of Stockton's made with 3.5" bs, 16x10. and 38x14.5 Toyo's.
No rubbing until my trac bar went bad, instead of steering the axle shifted side to side and tire rubbed the frame, Teraflex forged trac bar fixe it and alls good!
Old Feb 11, 2009 | 06:18 PM
RubiJK's Avatar
Well, if you consider a 12.5" tire on a 4.5" bs wheel is the norm and works well... 14.5" is 1" wider per side... would be the equivalent if you ran a 3.5" bs wheel. Or you achieved bs from spacers. I would only GUESS that you can get away with the 3.75" too but you COULD have a little rubbing on your sway bar links if anything. 1.5" spacer and you will be golden.
Old Feb 11, 2009 | 07:01 PM
MOWrangler's Avatar
I've got the same soft 8's running Swamper TSL's 36x13x16's with spacers. They seem to do OK (no rubbing so far), but I'll know more after taking it out this weekend.
