Backspacing?
Old Aug 2, 2009 | 10:48 AM
JamieRay's Avatar
Default Backspacing?
2009 JK with 33s. What is the proper backspacing needed? Looking for a good flush tire and fender look. I would like to increase the footprint a bit but not so much that they stick out and look retarded. Thanks
Old Aug 2, 2009 | 11:00 AM
wayoflife posted this info up and its pretty useful
https://www.jk-forum.com/forums/show...74&postcount=3
I went with 4.25" of BS on 16x8 rims and will be running 285/75R16 ( 33's or close to it) I think you'll almost have to expect some tire sticking out maybe a bit, or else you'll rub in full turn.
Heres the main link to all the info regarding our jeep specs
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Old Aug 2, 2009 | 11:02 AM
JamieRay's Avatar
Right on, thanks.
Old Aug 2, 2009 | 11:08 AM
JPop's Avatar
It's dependent on wheel and tire size. In your application and not knowing the tire width, 4-4.5" with an 8" wheel and 4.25-4.75" with a 9" wheel.
Old Aug 2, 2009 | 02:00 PM
RN M OVR's Avatar
As long as you go no higher than 33" and no wider than 11.5", you can get away with 5" of backspacing which will sit the outside of your tires just about flush with the fender flare and have no rubbing. NOTE: this works well with 16" and 17" wheels.
I will also suggest a leveling kit or 2" budget boost to complete the look.
This is my new-upcoming set up and it will work.
