Backspacing on AEV Savegre wheels?
Old Mar 29, 2010 | 09:19 PM
Hellbound13's Avatar
Default Backspacing on AEV Savegre wheels?
Does anyone know what backspacing these wheels are?
Quadratec lists them at 5.25..
http://www.quadratec.com/products/92500_1332_07.htm
and the Pintlers at 4.7..
http://www.quadratec.com/products/92500_10X_PG.htm
but I remember a few people saying the two wheels were the exact same fitament so how can that be?
Old Mar 29, 2010 | 10:04 PM
spinlock's Avatar
They are listed as having +10mm offset (~0.4"). Since they are 17x8.5, the backspacing is 4.65" (nominal 4.7" just like the Pintlers).
Old Mar 29, 2010 | 10:05 PM
I figured as much. Quadratec was wrong. Well thats too far from stock for me. The search continues..
Old Mar 29, 2010 | 10:08 PM
spinlock's Avatar
What do you mean "too far from stock"?
They are perfect for 11.5-13.5" wide tires without the need for spacers. That is what they were designed for.
Old Mar 29, 2010 | 10:14 PM
I am running stock sized tires though. 255/75/17. I assume those are not a good match for these wheels.
Old Mar 29, 2010 | 10:27 PM
spinlock's Avatar
They will probably still work. Tires that size usually can take rims in the 7-9" width range. Check the manufacturer's specs for your specific tires.
Old Mar 30, 2010 | 02:40 AM
Maddmauler's Avatar
Also it appears the link you provided for the savegre wheels is a 5x5.5 bolt pattern. Thant is probably where these different backspacing figures are coming from.
Old Mar 30, 2010 | 02:42 AM
Maddmauler's Avatar
Yup just checked if you go to the savegre wheels with 5x5 bolt pattern you will see that QT has them listed as 4.7 backspacing.
Old Mar 30, 2010 | 04:25 AM
redrockin7's Avatar
I ran stock sized Rubi BFG MTs on my blackrock wheels (4.5" bs, 17x8) for about 15,000 miles until I got my 35s. Personally I thought it looked a lot better than stock with the wider stance.
Old Mar 30, 2010 | 06:29 AM
But won't I have handling and ride issues since Im not lifted and putting stock tires on this backspacing will drastically effect scrub radius?
