backspacing help with 37x12.50
Im going to run a 4" suspension lift or a 3"suspension lift and a 1" body lift.
I want to run 37x12.50 tires with 17s or 18s. What backspacing will I need so I dont rub? I dont want to run spacers.
Then you dont need to worry about Wheel spacers or BS.
I wouldnt suggest BL on JK's they looks silly, and are not needed..
I'd go for a 4" lift, What company are you looking at?
I want to run a 4" Superlift with Bilsteins.
37x12.50 Goodyear MTRs or 37x12.50 Toyos
5:38 gear... suppose to be out in Jan
I was thinking about the Rancho 4" long arm kit but I dont plan on wheeling it that hard.
I have the AEV pintler beadlocks which are 4.6" backspacing and the 37x12.50 tires rub both the frame and the lower control arm. I can raise my truck up to about 6" over stock and it only gets a little better but does not go away at full lock.
I would recommend a 4" backspacing with those tires.
It doesn't matter WHAT suspension lift/body lift combo you run, you HAVE to change your backspacing either with new wheels or spacers when you run bigger tires. I think this issue has been fairly well aired on the forum thus far.......
he doesnt know what the hell he's talking about.. let it go
