backspacing ? for peoples running 35/37 inch tires
is anyone running wheels with 5 3/4 backspacing.....or do I need to get a 1 or 1 1/2 wheel spacer.....Im not going to do that much (if any offroading)
Yeah, 5.75" of BS will get 12.50" wide or wider tires to rub. You really need about 4.5" to clear everything so if you already have new wheels, you might want to pick up a set of 1.5" wheel spacers like Spidertrax makes.
Sorry Ryan, this is incorrect. JG, I am running 35x12.50x18's on 18" wheels with 5.25" of backspacing with no problems. 4.50" might be ideal, but anything under 5" should be fine.
Really? I am running 35x12.50's on 15x8's with 4.75" of BS and the shoulder lugs just barely kiss my lower control - not enough to hear but enough to see a small shiny spot developing on them.
Hmmmmm, WoL, mine are fine. I had originally gotten 1/4" spacers because I didn't think that they would be (because everything that I had read said you needed 4.5" or less). My wheels are 18x8.5" with a +12 offset, that equates to 5.25" of backspacing. The only rubbing that I had was on the airdam but that thing has long since been trimmed. I know there are a few others on here (Mudpuppy and Rebel) that are running my wheel now, but I think that I was the first on here to have them. Maybe one of them will chime in about any rubbing issues if they have them, but I don't.
blkrubi...do you think i should go with a one inch spacer with 5 3/4 backspacing with the wheels or will i be ok....i have 37 inch Nitto Muds on the way....I have the ultra black goliath wheels.....
also my man....im getting ready to do the fog light install on the mopar bumper...i might be hitting you up for some more help...thanks jeep brother
