Backspacing VS Offset GRRRR!
Old Jun 20, 2009 | 02:26 PM
Goose0077's Avatar
Default Backspacing VS Offset GRRRR!
Hello! Love the forum! I did the math with backspacing coverted to offset at http://1010tires.com/WheelOffsetCalculator.asp but just made my self more confused / Stock rims are 6 in Backspace and when I coverted to offset...well thats when the headache started..I might be trying to over think it
I Have a good grasp on backspacinge BUT:
T285/70/17 Duratrac Wranglers will be the shoes, est. 11.2 wide 32.7 high
The rims I want to get (XD-SPY Black) are available for my app in two sizes
17x8 offset +18mm
and
17x9 offset -12mm
What the?
Please please help, this is stoping me from ordering cause I dont want to get the wrong ones
I would like most of the tire under the flare, inch over not bad, but not sticking out 3 inches
I found a company that doesnt have spys on back order for 2 months / stated in stock!!
Thank you for your time!!
John G.
Old Jun 20, 2009 | 03:46 PM
Cpt. Flapjack's Avatar
I'm running the same Duratracs on a +10mm offset on a 9". The rear wheels are VERY close to the swaybar links on a 2.5" lift. I think the +18s would be too much backspacing. The tire clearance seems to be good all the way around.
Old Jun 20, 2009 | 03:49 PM
Use this site to compare. Works great
http://www.1000rims.com/rt_specs.jsp
Not sure about the policy on posting links. If its a problem let me know.
Old Jun 20, 2009 | 04:22 PM
Goose0077's Avatar
Backspace to Offset Conversion Chart
I found this
Old Jun 20, 2009 | 08:29 PM
nangulator's Avatar
I found this
I dont do math. I have 17x9s and 35x12.5x17s,(wheels have 5 inch BS), no rubbing issues even aired down to 15psi
Old Jun 21, 2009 | 11:03 AM
Goose0077's Avatar
Nice! Thank you Cpt.
Old Jun 21, 2009 | 01:02 PM
Goose0077's Avatar
Default mhmm
OK!
17x8 has 5.2 inches of back spacing
and
17x9 has 4.5 inches of back spacing
Tires are 285/70/17 @ 11.2 wide and 32.7 High
What do you recommed?
Since No Lift yet, from what I have heard the 5.2 is to close to the Jeeps internals I have seen some 5 inch deep with no lift, no problems, the guide for dummys says we shouldn't go over 4.75
Did I answer my own question?? I edit my posts a lot!!
Old Jun 21, 2009 | 04:14 PM
I run 5" on 9"wheels and it is very close.
Old Jun 21, 2009 | 04:23 PM
wrnglrguy's Avatar
I would go with 4.5" of backspacing. That is what is needed to run 35x12.5. I know you are running a little smaller, but it is better to have the 4.5" backspaced wheel. That way, you know your clearance will be good, and, if you do go to a larger tire down the road, you'll already be set up for it. Besides, something I have learned over the years...15" wheels are easy to find the size tire you want...17" wheels also have a larger choice of tire sizes...but for some reason the 16" wheels have less choices in tire sizes. I don't why that is. The 17" tires will cost more, but the selection is better.
Old Jun 21, 2009 | 04:36 PM
Goose0077's Avatar
Default Thank you!!
Cpt. and wrnglrguy
Thank you for the Info!
