Bad control arm bushing cause DW?
Thanks for all ur help planman. I am hopefull that I havent done any damage since all the incidents have been at pretty low speed and only lasted for a few seconds each time (30mph). I am anxiously awaiting my new stuff to get it on. Unfort I have cont to drive my jeep around town because it is the only vehicle I have. I have been limiting my driving as much as possible.
I havent check the ball joints yet since I have only put 12,000 miles on me jeep, seems unlikly that they could go that fast, right?
Thanks guys for all ur help and bearing with me.
I pulled my track bar bolt at the axle to check it out. Here r some pics. Does this look normal or is the hole enlarged? I dont know how tight it is supposed to be. the bushing appears visually fine. not sure how else to check.
Here is it with the bolt pushed through both sides with track bar out.
What do you guys think?
Im not 100% sure but I thought it was supposed to be a pretty tight fit.
When the bolt is through is there much play ?
I asked this same question and I was told find a washer thats tight on the bolt and weld it to the bracket when the hole is enlarged.
Im new to this stuff so I would wait for someone with more experience to chime in.
This one:
http://www.quadratec.com/products/16007_0100.htm
I would agree with planman in it looks a lil bit loose.. I do not think mine has that much space... the hole on mine is just big enough for the bolt..
Time to weld washers on.. can't hurt.
Sent from my Droid
Sent from my Droid
Thank u so much again guys. If u were closer I would buy you all lunch. If you are ever in Olean NY look me up
I am going to buy the jks bracket brace and have someone weld on a washer on the back side. Looks like the JKS trackbar brace comes with a new trackbar bolt so I will wait to see what size I need.
What kind of washer do I need, any old grade 5 or does it need to be a grade 8? How do you weld the washer on in case my welder asks? do you put the bolt through and secure it someone to make sure it is welded in the right spot?
Ill get this DW fixed yet.
.I am going to buy the jks bracket brace and have someone weld on a washer on the back side. Looks like the JKS trackbar brace comes with a new trackbar bolt so I will wait to see what size I need.
