Ball Joints Who's do you run
Old Mar 5, 2013 | 03:38 AM
BrowniesJK's Avatar
Default Ball Joints Who's do you run
My Ball Joints are done.... Who's do you guys prefer and why?
Old Mar 5, 2013 | 03:43 AM
Hskr4x4's Avatar
I run Synergy.. Top two brands are Dynatrac and Synergy. Alloy just came out with them but haven't been on market long enough to have true results
Old Mar 5, 2013 | 03:45 AM
FoxRacingJMC's Avatar
DynaTrac all the way.... If you need to ask why, its because they are the best. git-r-done
Old Mar 5, 2013 | 04:29 AM
kjeeper10's Avatar
Vet Army
Synergy for me
Old Mar 5, 2013 | 04:34 AM
Colegrove03's Avatar
Dynatrac prosteers. Worth every penny but are expensive!
Old Mar 5, 2013 | 04:44 AM
Bonedoc's Avatar
I have the synergy ball joints. An excellent upgrade from stock. I have over 40K miles on them running 37s and they are still tight!!
Old Mar 5, 2013 | 04:54 AM
tcdawg's Avatar
I replaced by stock ball joints with Synergy joints about a year ago. They are holding up well to 37's and monthly wheeling.
Old Mar 5, 2013 | 05:08 AM
c4bus's Avatar
Synergy BJs all the way. Cheaper than stock, they have grease fittings, they're all metal, and they've been field proven to stand up to big tires, and rough trails.
Old Mar 5, 2013 | 08:33 AM
BrowniesJK's Avatar
Synergy is what I was leaning towards. Sounds like I just need to pull the trigger. Thanks guys.
Old Mar 5, 2013 | 08:36 AM
chris@offroadevolution's Avatar
Sponsoring Vendor
Originally Posted by Colegrove03
Dynatrac prosteers. Worth every penny !
High strength billet steel and heat treated bodies.
Super strong chromoly steel, heat-treated stems.
Effective seals prevent contamination and promote long ball joint life.
Fully greaseable on the truck.
Heat treated, precision ground stainless steel ball conforms to Military specifications.
Teflon coated internal wear points.
Fully-adjustable cup support protects against severe road impacts.
MADE IN THE USA
