Balljoints?
Old Nov 4, 2011 | 04:00 AM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Default Balljoints?
Ive been combing the threads for a while and it seems that balljoints fail ALL THE TIME especially with larger than stock tires. So my question is, should I just replace them now or wait until they wear out and become potentially hazardous?
Old Nov 4, 2011 | 04:01 AM
Schwheelz's Avatar
I have been running 33's on stock ballpoints for 2 years now, it's a 09 x 2dr. They are fine
Old Nov 4, 2011 | 04:13 AM
jpkjk's Avatar
No sense in changing them till they go bad an if they go bad . I had passenger side go bad and jeep dealership also replaced drivers side under warranty since I was so close to warranty running out and I had stock tires on with 3.50 rk suspension. Gotta love some of the dealerships
Old Nov 4, 2011 | 04:35 AM
HappyCurmudgeon's Avatar
Eternal ***erator
50k miles on my stockers, about 40 of which is running 33's. Mine are just beginning to show wear, but not enough to warrant replacement just yet. I personally wouldnt bother until it was required.
Old Nov 4, 2011 | 04:46 AM
SergeantChuck's Avatar
I see where your coming from and I just did exactly what you are reffering to. I experienced DW three times. I found the problem (track bar) which was not the ball joints but since the front end had taken such a beating I bought and had ball joints (MOOG) replaced. I did it solely for my piece of mind. I wouldn't suggest just swapping them for no reason if they are good but I had the funds and it was one less thing to worry about down the road.
Old Nov 4, 2011 | 06:18 AM
Gforce!'s Avatar
Thanks for the info guys! It was very helpful.
Old Nov 4, 2011 | 06:28 AM
spedly's Avatar
I had significant play at 7k miles. It was enough play to cause death wobble if I hit a bump over 40mph.
Old Nov 4, 2011 | 06:55 AM
TheTerminator's Avatar
Wait till they go bad. You'll have plenty of time to replace them once they do. It's not a timing belt.
Old Nov 4, 2011 | 08:04 AM
jmontgomery's Avatar
Stock ball joints are junk. If you buy replacement balljoints from the dealership they'll have a 2000 mile warranty. Pure junk. When you replace yours go with a quality brand.
Old Nov 4, 2011 | 08:19 AM
Pcgizzmo's Avatar
What does it typically cost to replace them with a good quality ball joint?
