Banks Turbo Install on a 2011 JK Unlimited
The cost for the lift is a 3.5 Rubicon express short arm full kit, new front driveshaft, labor to install and align. I wasn't the first to have the system installed on. ..but I was the first with stock suspension. I did get 500 off the cost to let them keep it for the initial 2 weeks
I am running full Metal cloak armor and only use this jeep to trail ride. Running 37's gives me the extra ground clearance I wanted.
I have an 04 TJ that I use for having fun and beating on. My girlfriend drives this jeep every day and wanted it to retain the stock ride and keep a LCG.
Evo Double throwdown is about 12K before labor and driveshafts. Evo Double D pro is well over 6K before labor and driveshafts.
I could not hardly go offroad at all with a 2 inch AEV lift and 35's.
Why go 37's and cant take it offroad? Looks alone?
I am running full Metal cloak system and only use this jeep to trail ride. Running 37's gives me the extra ground clearance I wanted.
1 Post
IMHO, they should've given you a pretty decent discount for being their "guinea pig" if they've never installed their kit on a stock Jeep. But hey that's me. At least they're offering to help pay for the lift, hwich they should.
I'm curious, too, though....what lift did you order that's costing you $3300? Evo Double Throw Down? Something that uses coilover up front? Even with full long arms, etc., most good kits run under $3000 including shocks, etc. Also curious how you're running 37's on stock suspension. Pics?
So what's currently installed on your Jeep? Stock suspension or Metalcloak? Without some serious cutting, I don't think it's possible to run 37's on stock suspension.
This post doesn't make any sense. First you said you're running stock suspension, or at least were when Banks installed the turbo kit. Next you say you're running a full Metalcloak system. Obvoiusly not stock suspension. And then $3300 for an RE short arm? Could've installed all of that yourself in your garage, including control arms, drive shaft, etc. nad saved a few pennies.
I can go offroad, see photos. I dont need crazy flex on this jeep as I dont take it through the hard stuff. Just use this jeep for trail riding, hitting the dirt roads to go to the river, etc. My TJ is smaller and narrower so I use that for the fun stuff. Metal cloak fenders help give you the clearance needed for bigger tires that I wanted for ground clearance. A lift would not help with ground clearance. It may not be for everyone but it works for me. Building the JK has been a slow steady process and we have done what was needed and wanted first. audio is done, tires done, bumpers done, winch done, fenders done, now lift will be done and the turbo kit. next will be front runner roof rack, then axles and lockers.
I looked at the metal cloak lift and I love what they make. I went with the rubicon express lift due to Mike Barnett's (owner of jeepspeed) recommendation for my set up. I have the metal cloak fenders front and rear, rock rails, corner armor on BOTH of my jeeps. You dont need to sell me on metal cloak, I am a customer of theirs for life. Everything is personal choice. my axles are stock on the JK and they will be until the need arises to upgrade them. I dont put this jeep through anything harsh, like I said this rig is for trail riding NOT rock crawling. I have other vehicles for that. I was trying to say that I was not going to accept a 2inch coil spacer kit as a suitable fix. A coil spacer kit is a cheap alternative to a real kit, and thats fine if that is what you want on YOUR rig. I'm not here to fight and bicker with anyone, guess that comes with the territory of forums. Everyone has their own opinions.... I was simply trying to let everyone one know what kind of experience I have had with this system from banks. Next time I will keep it to myself and not help anyone out. why didnt you go with the metal cloak lift? or fenders for that matter?
OP....thanks for clearing up the Metal Cloak/stock suspension thing. Makes a lot more sense now; although, I'm sure your Jeep actually sits a tad lower because of the additional weight from the armor, etc. But 37's do wonders for ground clearance! I'm only on a 2.5" RK lift, but with my 37's, there's not a trail/obstacle I haven't been able to overcome. Truth be told, I think my Jeep is more capable than my balls allow me to be.
I'm impressed that you fit 37's on stock suspension, though. LCG like a boss!
