bare aluminum
Old Apr 23, 2012 | 07:33 AM
CommandoOkie's Avatar
Default bare aluminum
Dont want to start a steel vs. aluminum debate, just got a question about aluminum in general. If your going to abuse it, does it need to be painted or anything? Can I just leave it bare if I like the look?
Old Apr 23, 2012 | 07:37 AM
B.S.'s Avatar
You can leave it bare.
Old Apr 23, 2012 | 07:52 AM
Mr. Smiley's Avatar
I wouldn't leave it bare for fear of rusting.. either paint it metal colored or clear coat the shit outa it..
Old Apr 23, 2012 | 07:56 AM
B.S.'s Avatar
Aluminum wont rust but will lose its luster when exposed to the weather just like aluminum boats do.
Old Apr 23, 2012 | 07:57 AM
JK-Firecracker's Avatar
You can leave it bare.....however, that said. It WILL develop a thin "dust" of sorts as it is oxidizing. It will need to be cleaned more often if you want to retain the shiny appearance. IMO, bare aluminum looks sweet when left to the elements!
Old Apr 23, 2012 | 08:01 AM
JKbender's Avatar
There is no need to paint Aluminum. However you should wax it when you wax the rest.of the Jeep. This will bring back the like new shine and give it a layer of protection that keeps that shine longer.
Old Apr 23, 2012 | 10:29 AM
pancake's Avatar
+1 on leaving it bare and waxing/sealing. However, use a high quality wax to avoid white wax residue buildup or yellowing over time. Aluminum can also be "cleaned" with 000 steel wool or a soft Scotch Brite pad. This will remove oxidation and prevent pitting. You could also polish the aluminum, that's pretty easy. American Airlines planes are typically raw aluminum that has been polished. They do that to save the weight of paint to increase fuel efficiency
Old Apr 23, 2012 | 12:11 PM
Thanks every one. Just went with the steal. The weight diff just wasnt there for me. But thats just me.
Old Apr 23, 2012 | 03:49 PM
williard86's Avatar
Default flitz
Flitz makes a past that polishes aluminum really well. It's what they use on airplanes alot of times.
Old Apr 23, 2012 | 04:25 PM
Prime8's Avatar
Aluminum doesn't rust. It immediately forms an aluminum oxide layer when it touches air and this molecularly thin ceramic layer shields it from further corrosion. I left my aluminum Spyderlocks bare because it was expensive and neither liquid paint nor powdercoat does well on wheels.
