Battery options - Odyssey worth it?
Old May 29, 2012 | 07:49 PM
Vladimer's Avatar
Default Battery options - Odyssey worth it?
Hi everyone, it is time to replace the battery. Its an '08 and woke to the Jeep barely able to start. I've searched around on the forum and the optima seems to still have a decent following and the die hard platinum seems to be popular.
I currently have aux lights on the windshield and a cb. Down the road I plan to add more lights, winch and possibly more accs so it is probably smarter to go with a deep cycle battery.
I've had the optima yellow top in the past in my car about 5 years ago, while it 'performed' good ... I did have to get it replaced under warranty once and then it died again shortly after there borderline crappy warranty as well. So rather uneasy going with an optima again, especially with the cost.
I'm in canada so the die hards from Sears arnt available. Currently the cost of a normal battery is 130, the optima is $250 and the odyssey is $330. I haven't found a single bad thing about the odyssey but it is $330 here ...
Is it worth going with the odyssey? I don't want to get stranded on a trail in the future with a battery that can't handle a winch but at the same time $330 is a pretty big pill to swallow battery ...
Any advice?
Thanks
Old May 30, 2012 | 03:45 AM
Ryan0260's Avatar
I believe the die hard and Odyssey are the same battery, and both get great reviews
Old May 30, 2012 | 04:02 AM
holmes4x4's Avatar
What about running a dual battery settup? I preffer the optimas personally ran one in my XJ never had a problem plus the price point is much better.
Old May 30, 2012 | 04:57 AM
knnphillips's Avatar
Funniest thing ever is my 08 battery just died today. What are the chances 2 will bite the bullet this close together.lol
Old May 30, 2012 | 05:09 AM
robsjeep9's Avatar
JK-Forum Ambassador
I was lucky and saved $30 on the Odyssey still $300 but so far no issues running a winch, windshield lights etc and great warranty to 4-5 yrs I believe. Im in Ontario Canada.
Old May 30, 2012 | 05:43 AM
dognights's Avatar
I use a ballastic battery setup. They are very small lightweight dry cell batteries. You can actually fit two batteries in your normal battery box, three if you are creative a bit. Some wire and a marine selector switch and you have a nice custom power option. These were orginally made for motorcycles and powersport applications for harsh enviorments and racing. You can get a 500 CCA deep cycle battery that weighs only 3 and a half pounds that is small enough to fit in your glove box if you wanted. These are not direct replacement type batteries, but are a reliable solution with some creativity for emergency power and high load capacity out of a very small space.
Old Jun 4, 2012 | 05:31 AM
Matador's Avatar
I have an 08 and my battery needs to be replaced as well....plus just noticed a bunch of corrosion on the terminal
Old Jun 4, 2012 | 05:48 AM
wayoflife's Avatar
JK-Forum Founder
The diehard platnum p-1 are odyssey and, after years of running optimas, i now only run these.
Old Jun 4, 2012 | 06:12 AM
Matador's Avatar
The marine one or just regular one?
Old Jun 4, 2012 | 06:16 AM
wayoflife's Avatar
JK-Forum Founder
i just run the regular gray body one. not the blue marine.
