Battery Terminals.
Their position was that amp-hour capacity wasn't guaranteed, and/or the testing was somehow flawed. Still have it sitting in the garage -- The intended use wasn't automotive, it worked fine other than low amp-hour capacity.
Amp/Hr of a NEW battery not guaranteed?... "not nice"... but it's also true is that this can be measured by different methods which yield different results.
Looking back at the email exchange, the Optima tested 75% of rated based on the C/20 AH rating. The Odyssey's tested > 95%. Only a test would show this, either will start an engine under normal conditions. But a battery with more amp-hour capacity clearly has advantages. As a disclaimer -- This was a very small statistical sample of Optima batteries (two to be exact, and these were the same size), and it was almost 3 years ago.
There are tolerances to any measurement test, just like manufacturing. Not claiming this was a certified lab accuracy test, but if it had been an instrumentation or methodology error, similar batteries would also have tested low.
Could the battery you tested possibly be from the early production in Mexico, when they had quality problems?
