Bead locks
Old Dec 26, 2015 | 02:05 PM
  #41
Rob 12B1P's Avatar
Originally Posted by mhockey9090
in 2.5 years I only have 23k on the Jeep. I do not make long trips over 2hrs, unless I'm moving to another location. I maybe put 20 miles a day on my rig. From what I was reading is that you just need to check the torque on the bolts every other week to ensure they are still tight. I guess if I'm doing a longer trip, just making sure I bring the torque wrench with me and check it during a quick stop.
I check mine after wheeling trips and at oil changes.
Old Dec 26, 2015 | 02:29 PM
  #42
Invest2m4's Avatar
Same here. I've had a few sets and find that after first mounting, they usually need to get tightened a few times over the first couple months. After that, they stay pretty tight. A few wheeling trips will loosen them a bit. It's easy to check, so I do it when I think about it.
Just get a good torque wrench and one of proper size. A 20-100 ft lbs wrench is not going to work. The accuracy is way too far off. Ideally, 0-50 or 0-70. And click type.
Old Dec 26, 2015 | 02:46 PM
  #43
mhockey9090's Avatar
Vet Army
Ok cool. I guess I will order these bad boys and get them here, so I can use them in time for winter jamboree here in Sand Hollow. I will get what I need to mount them myself as I'm sure they will want to charge an arm and a leg for that.
I don't care for the TPMS and don't feel like spending the additional money for them.
So are there certain type of valve stems I should order or stay away from? I know I'm going to pick up the valve stem install tool and a better torque wrench.
Just curious as if my ARB twin will be able to seat bead of the tire instead of bringing the tire to a shop for that.
  #44
shabbernigdo's Avatar
rockmOnsters need 100 ftlbs so you will need something bigger if you get them.
Old Dec 26, 2015 | 03:03 PM
  #45
Invest2m4's Avatar
Eh, good catch. I'm thinking ATX anything where it's 22 ft lbs.
Old Dec 26, 2015 | 05:54 PM
  #46
sea bass's Avatar
100 ft/lbs? Seriously?? Mine sucked bad enough torquing everything to 20lbs. I cannot even imagine how many rotations around each rim to get up to 100lbs. Those must be seriously beefy.
Old Dec 26, 2015 | 06:28 PM
  #47
Vet Army
Something keeps me from hitting pay on the beadlocks. I guess the only thing is that in the long run I will be getting D60s and most likely end up in 8x6.5 bolt pattern, but I'm sure that will be in like 2 years from now.
I hate these type of decisions.
Old Dec 27, 2015 | 03:15 AM
  #48
Invest2m4's Avatar
Something keeps me from hitting pay on the beadlocks. I guess the only thing is that in the long run I will be getting D60s and most likely end up in 8x6.5 bolt pattern, but I'm sure that will be in like 2 years from now. I hate these type of decisions.
Sell them when you're done. I had Slabs on JK axles. Went to tons. I bought Chamber Pro's and then swapped rings with the slabs. Basically, I sold my slabs in like new condition. I got $150 less than I paid for them. Nominal in my view.
Old Dec 27, 2015 | 06:18 AM
  #49
Wrangeler X's Avatar
Alright guys I'm about to pull the trigger on some 5 x 17x9 Method 105s Matte Black beadlocks for $1358 shipped to my door. Who is running deadlocks on a daily driver? I know they are not DOT approved, but who does it? Any issues?
Where did you order them from?? Northridge 4x4
Old Dec 27, 2015 | 07:20 AM
  #50
DEADGUY11's Avatar
Wondering as well
