beadlock ring ? (AEV) do i need to change rings when changing tires
switched from 35 to 37s and ordered new bolts. was rec. to order new rings $500 for 5 . after mounting first ring radius was smaller 1/16 and depth was deeper on new ring 3/16 compared to old rings after 1 hour of trying to get it @ 15 ft/lbs was only able to get to 8 to 15 on the bolts. mounted old rings on the rest of the tires the last 3 days and all are holding air fine. ? should i exchange the new rings or return them .
