Beadlocks
Old Feb 14, 2012 | 04:07 PM
tapp's Avatar
Default Beadlocks
Are bead locks really necessary? And why are there imitation ones. I was looking at the Mickey Thompsons but found out they wasn't true bead locks
Old Feb 14, 2012 | 05:33 PM
Merlin4979's Avatar
Nah. They're not necessary in the same way lockers aren't really necessary. They're just another tool that helps 4-wheelers go a little more extreme. You don't "need" them to go wheeling, but with them, you can get to lower PSI, which means better grip off-road, and so on. They are more expensive and require maintenance though.
They make fake beadlocks...just because they look cool.
If you DO want to get some good looking true beadlocks, check out
Hutchinson Rock Monsters
Raceline
ATX Slabs
Spyderlock
Method
Walker Evans
...and so on.
Old Feb 14, 2012 | 05:57 PM
sacdaddy03's Avatar
Champion has some sweet designs also. Beadlocks on th cheap will be Trail Worthy Fab, just spend more on tires because of thier 16.5 size.
Old Feb 14, 2012 | 06:32 PM
tapp's Avatar
Thanks I will look into them. Rather spend the money once and do it right the first time
Old Feb 14, 2012 | 07:10 PM
kleinrider's Avatar
Merlin pretty much said it all for you. I will add that I wouldn't buy 16.5" wheels these days. I wouldn't spend more money very time I replaced my tires when I could spend a little more once (when I bought the wheels).
Old Feb 14, 2012 | 07:29 PM
tapp's Avatar
So should I go 16s? Since the 35s are cheaper
Old Feb 14, 2012 | 08:38 PM
tapp's Avatar
Should I go 16s and what off set? Not too smart on wheel choices
Old Feb 15, 2012 | 12:42 AM
JaySC's Avatar
How do beadlocks drive on-road? I've heard some nightmare stories about sudden flats, etc. from running beadlocks on a dd.
Old Feb 15, 2012 | 01:07 AM
wildandwillin's Avatar
go with 17s you will have more tire choices
Old Feb 15, 2012 | 01:09 AM
I can not even tell the diffrence. BUT..... with beadlocks come more maintenace. You will need to always check your bolt tightness after every offroad trip. Also you need to watch for damaged bolts. Never had a flat or a issue with my Racelines.
