Beefing up dana 30
Old Jan 26, 2013 | 08:20 PM
AaronOB's Avatar
Default Beefing up dana 30
I am looking at building up my Dana 30 front axle on my 2007 sahara unlimited. I am planning on the Artec Industries JK Front Axle Truss
as well as the EVO: Gussets/Brackets, EVO Mfg 44 Magnum Sealed JK/TJ Axle Sleeves.
My question is can these two products be combined and what else should I look into for a stronger axle.
Old Jan 26, 2013 | 08:35 PM
jkkrawler's Avatar
The artec truss already comes with knuckle gussets. All you would need would be the sleeves. I personally would get the nitro sleeves.
Old Jan 27, 2013 | 12:41 AM
jkhutchison09's Avatar
x2 on the Nitro Sleeves, no drilling and welding required. C Gussets are a must if you plan on running larger tires/wheels. I'm waiting for chromoly shafts until my factory shafts break. Truss kit would be a little over the top if you are putting in a sleeve IMO.
Old Jan 27, 2013 | 06:55 AM
familytime's Avatar
JK Forum Regional Rep
The axle housing truss/sleeves will take care of the housing.Running them both together may seem overkill to some.The weak point is the axle shafts and u-joints,replace with chromoly axles with full ring heavy duty u-joints
Old Jan 27, 2013 | 09:21 AM
tlminh's Avatar
The arctec kit comes with c gussets? Really? Doesnt seem like it
Old Jan 27, 2013 | 09:34 AM
xj2jk's Avatar
It doesn't. At least when I bought mine it didn't . I got them separately.
Old Jan 27, 2013 | 09:49 AM
Smashboogie 4x4's Avatar
Former Vendor
They sell it with and with out. Here is a link for the kit that has the c gussets.
Artec JK Front Axle ARMOR KIT
Old Jan 27, 2013 | 10:54 AM
orangedude71's Avatar
You do all your own welding when installing the truss/ gussets? Anything tricky?
Old Jan 27, 2013 | 01:28 PM
Former Vendor
If you upgrade your axle shafts and u-joints then your weak point becomes your pinion gear. I'd rather break a u-joint or axle than a pinion gear.
Old Jan 27, 2013 | 03:39 PM
Ryan0260's Avatar
Yep. The only way to strengthen the pinion gear is to go with a bigger axle.
