Bending axles question
Old Nov 29, 2014 | 06:59 AM
Clark Collins's Avatar
Veteran: Navy
Default Bending axles question
I have a 2010 JKU Sport and recently swapped in 2014 Rubi axles (w/5.13 gears, C gussets, RCV & G2 shafts and RuffStuff covers) that I purchased from a fellow jeeper. I've now upgraded to 315x75x16 tires that actually measure 34" from the 285x75x16s I was running. On this forum there is a lot of discussion about the weaknesses of the stock rubi axles and if they should be sleeved and/or gusseted.
My question is: What have people been doing when they bend or break their axles? Do I need to consider any modifications to these axles?
I'm very satisfied with the performance of my 3.8 running the superchips 87 octane tune and the new gearing and tires. With the RCV and G2 shafts I shouldn't have any problems there. I'm not intending to ever run larger tires and I don't plan to do any jumping or serious rock crawling. I do run in the sand and on intermediate type trails. We will likely go to Moab someday, but don't plan on doing any trails that risk body damage as this is my daily driver.
Old Nov 29, 2014 | 07:19 AM
Rebar-7's Avatar
I think your good to go with the type of off roading you intend to do. With the RCV's the weak link
Will be the R & P 5:13's. I guess if you had some extra cash to spend you could truss the front....
Old Nov 29, 2014 | 07:40 AM
TheDirtman's Avatar
I would not worry about it unless you are abusing the jeep.
Axle strength is one of the most over hyped things on the forums.
