Best 2" Lift Kit
Old Apr 23, 2012 | 06:48 AM
CarFanatic's Avatar
Default Best 2" Lift Kit
I just got my 12 JKU. I want to do a 2" lift. I'm only going to run 33's or 34's. Whats the best kit for a 2" lift that will still be a nice ride for daily driving. Will do some mild off roading as well nothing extreme.
Old Apr 23, 2012 | 06:52 AM
Mr. Smiley's Avatar
Well depends on your budget and which way you wanna go. Coils, or BB.?
Old Apr 23, 2012 | 07:21 AM
CarFanatic's Avatar
I"ll spend the money for whatever is the best quality in the long run. I had a full traction 3" priemum on my 08. But not going that extreme on this one. I Want the ride to be stock or nicer.
Old Apr 23, 2012 | 07:28 AM
Vincent's Avatar
There's the new AEV, the TF Leveling Coil or the spacer kit (I have the spacer kit)...depends on what you want. I either recommend one or the other of the above...if you plan to add weight (bumpers, winch, armor, etc.) then you should head in the direction towards coil springs. Plan long term & you will save $ in the long run.
Old Apr 23, 2012 | 07:33 AM
Jeek.OlllllllO's Avatar
Originally Posted by Canuckjkjeeper
i just installed the Teraflex 2.5" Budget Boost on the weekend and Bilstein 5100's.....i must say that it handles and rides much better than the stock Rubicon shocks. Cheap and effective way to fit 35's for a daily driver. I had zero issues with the install and the steering wheel stayed centered and no shakes or wobbles.
How much was it in total?
Old Apr 23, 2012 | 07:35 AM
CarFanatic's Avatar
I"ve heard the 2.5 turns out to be more like 3" though doesn't it?
What about the new Full traction 2" coil lift?
Old Apr 23, 2012 | 07:44 AM
Rock Krawler Suspension's Avatar
Former Vendor
You could always just start with some good coils and shocks at that small of lift height and start adding components as needed...
RK
Old Apr 23, 2012 | 07:47 AM
TeraFlex's Avatar
Sponsoring Manufacturer
If you want just a 2" kit, then you can go with either the #1155200 BB Leveling kit ($136.99) or the #1351500 coil version ($409.99). Both will retain your factory shocks, the BB kit will ride like the stock vs. the coil kit will be a little firmer.
Old Apr 23, 2012 | 07:48 AM
JK-Firecracker's Avatar
RK
Exactly. I picked up some OME springs and lifted mine about 2". Cost---$100 or so. Rides same or better than stock and sits up nice
Old Apr 23, 2012 | 07:50 AM
$450.00 was the total for me. I bought the 4 Bilstein 5100's slightly used off of another member for $200.00. The TF kit that i bought ( no shocks or adaptors ) was $250.00.
Took me and a buddy approx 3.5 hours with the help of a hoist and air tools. Very easy install.
Thanks im going to do this when i can afford my 35's lol
